Egg Plate
I've wondered for some time how to make something that seems simple, but I can't quite figure it out. An egg plate.
The idea is that you have a plate/tray/platter in which there are egg shaped indentations which is designed to present deviled eggs at a meal, often a church social or pot luck, or hot dish to you North Dakotans. My understanding is that these are essential components of any proper family kitchen in the South, but perhaps I don't have the name correct for such an important institution of good social graces.
Making the tray itself is straightforward, but how would you cut/carve/make the egg shaped depressions?
Thanks for your suggestions.
Thinking out loud here... it's basically the shape of scoop right? I wonder if a jig could be made with a curved platform so that a router with large cove bit could enter and exit the cut following the curve. Would take some trial and error but I've seen a similar method used to carve a chair bottom.
Some of the depressions are simple ovals like this flat board FDABE0B3-C99F-4E48-B6F0-B243A0DFAECF.jpeg
You could cut them with a router and a template.
Could fix the template in the banjo or clamped to the ways then you can use the index on the lathe to lock the plate for each cut.
A carbide plunge ball bit, oval cut in the template and a guide attached to the router base should do it.
Then sand with round balls
Could use a wide carving gouge from each end…
Could just free hand it with a 1/2” carbide ball burr. Cutting the outline groove with a palm vee or a small rotorary ball will help keep the big burr where it belongs. For a a rustic look - They don’t have to match
If you hand carve skip around the plate rather than going around. This will give a better look. If you go around the first and last are likely to be the most different because of some subtle drift in your technique.
