Ebonizing Solution Question
Fresno, Ca
www.beyondbark.com
I have been reading up on using steel wool and vinegar solution to ebonize woods. I have not been able to find any info on what the solution looks like. Here is what I mean. I expected the vinegar to eat away the steel wool after placing it in the vinegar. Is this what is supposed to happen? I placed some steel wool into 2 cups of vinegar, it has been sitting for a little over a week, and all I have is slightly dirty vinegar. It does not look like much has happened. Did I do something wrong? Is this what it should look like? Thought is was pretty simple (vinegar + steel wool + time = ebonizing solution) The steel wool I used came out of an unmarked bad I had for a long time so it make be the stainless steel kind which I know wont work. Please help.
Try it to see if it works!
Cypher:
By placing the steel wool in vinegar, you're just making iron acetate - a salt of iron in a low pH aqueous medium which will react with the tannin in the wood to create a dark black color. The best way to see if your solution is "done" is to try it on a test piece of wood known to have a significant concentration of tannin in it - try it first on a piece of oak or cherry to see if it stains the wood black. The vinegar may not ever eat away all of the steel wool fibers as a much stronger inorganic acid would (like sulphuric, hydrochloric, or nitric acid), but you may already have created enough iron ions in solution for it to combine with the tannins and turn your wood pieces black. If it doesn't seem strong enough, you may need to add more iron (longer soak of steel wool?), or use more concentrated vinegar/acetic acid. Warming the solution mixture may help too. If steel wool doesn't do it for you, try a small handful of non-galvanized nails (2d finishing nails in a glass jar half-full of vinegar have worked OK for me in the past) using fresh white (distilled) vinegar from standard grocery-store sources.
In this iron acetate ebonizing method, you won't necessarily have to neutralize the acid from the vinegar after the staining is done - just let it dry and sand off all of the 'burrs" raised from the solution.
Note that the wood used must be one having significantly high amounts of tannin in it to ebonize black enough to look like "real" ebony if you go the iron acetate route, and the species should be fine-grained to have a smooth ebony-like surface when finished - don't use ring-porous woods, for example. You can also use black dyes (including black boot dyes - ones that are used for shoes, military footwear, etc.) in water or alcohol solutions to be sure the black color is saturated uniformly in the wood. Hard maple has worked well for me using this dying method.
Good Luck!
Rob Wallace
Try it on some maple, let it dry, then let me know what happens.
Rob Wallace - Thanks for the info. Since i was not sure if the steel wool was the right kind i wanted to find out what the soultion should look like normally. Since now i know that the vinegar is not strong enough to eat away the steel wool i will not look for that as an indicator. For some reason i was expecting the soultion to turn black. (not sure why) I will give it a try on a test piece of wood. if it doesn't work i will try the shoe polish. I wanted to try it out on some tools handles i was remaking. thanks again.
Another solution is to use sodium dichromate. (Highly toxic) which provides a fantastic black colour. After drying of several hands of this saturated solution (one full spoon for half a litter of hot water), you put two more hands of campeche (campeche is a tree out of which, grinding the wood in very fine particles, is produced this colouring product)
When I make a solution of Iron Acetate it usually is a clear liquid (after I strain it). Whether the wood has tannin in it or not, I boil (nuke) a Lipton tea bag in three ounces of water until it is very strong. Paint the tea liquid onto the wood, let it dry, then paint the iron acetate onto the wood. The tea will cause a stronger reaction and darker color. Repeat if necessary.
India ink works great, and is much less trouble.
Gil
The solution I made turned dark brown, the difference is that I used a small collection of rusty iron objects, nails, railroad spikes, etc. that I happened to have. The iron oxide seemed to react even faster with the acetic acid, probably partly due to increased surface area compared with clean iron. Also, it was several weeks until I used the solution, so it had lots of time to react.
But boy, did that stuff work on a piece of cherry!
You can also get powdered tannic acid through dye suppliers. It mixes with water and is applied before the vineger solution for a good reaction on woods that are low in tannins.
The solutions I have made have always been black and dark and rather dirty looking before straining. This may have something to do with my approach. I use a 0000 steel wool and bathe it in mineral spirits to wash away any oil or other protective coating. Once soaking in the vinegar it only takes a couple of days for the steel wool to desolve.
I'm sure glad you posted this. I tossed about a quart of the solution after letting it sit for a month looking for "ebony". I guess I'll try another batch.
Mike
