I mentioned earlier my obtaining an 18" 250 and then a 20" 291. easy start5. Love the starting. However,the tensioning mechanism is one big PITA!!!!!. Does anyone out there have problem getting the bar/chain on right and then adjusted??? For those that don't know what I am talking about, there is a wheel attached to the bar that you turn to get the chain tight. Then you put the cover on but a little loose and then there is a notched wheel you use to tighten to final tension, or release when done for the day.
Both saws have a tendency to clog when ripping, even though I am careful not to hold horizontal very long so the ribbons can clear. But at the bottom of the cut to avoid hitting the ground, it goers horizontal. Takes about 2 sec of running to get clogged, necessitating taking the thing apart and chain off to clear. This happened with other chain saws but not so quick
This summer I took the 250 back and the wheel had become bent, making tensioning impossible. (under warrentee )The owner explained it's easier to get back on with a chest high work counter like he had. Yeh, right . as if I have a high counter out where I cut wood. Today I got the 291 clogged. and spent 30 min getting the bar back on (wheel didn't get bent). Mostly used ungloved hands for the dexterity of guiding the chain into the bar grooves GRRRRRRRR. Is this just me???????
Gretch
