Dying soft maple-
West Allis, Wi
I want to dye a soft maple bowl and i need some help.
The bowl will be 10' in diameter and 3" high.
Should I use a alcohol or water based dye?
If water base is the best way to go, should I try to raise the grain first?
I will be using a dark color( blue), does it usually take more than one coat.
And last what is the best finish for each type of dye.
Thanks, Jeff
Both alcohol and water will raise the grain, so do a couple set and sands before you use either. I use steel wool to defuzz what comes up after first dye, because it's not as prone to cutting through the dye on the surface. Second treatment is optional, but with curly soft, will usually show the most drama.
As MM says, both will raise the grain, probably because alcohol contains some water, but that is not really a problem. Some dyes such as TransTint can be diluted with either water or alcohol. I prefer alcohol because it evaporates much faster than water and I can speed it up to dry even faster by igniting the alcohol. Most of the time, it isn't necessary because it is already dry before I can grab my Bic charcoal lighter.
Before dying, I do a preliminary step of raising the grain using alcohol in a spray bottle. I always burn off the alcohol when I do this step because it serves the purpose of removing the fuzz as well as enabling the wood to more readily accept the dye. I do not sand the wood between this step and applying the dye.
I apply the dye very sparingly with either a paper towel or an old t-shirt. It is always easier to add more than to remove excess dye. After the alcohol flashes off, I sand with 600 grit paper to lighten the harder grain and increase grain contrast.
I don't know if you plan to layer the stain to get multiple colors, but if so, the area where you will apply the second color should be sanded even further to avoid getting the colors dark and muddy. I aim for dyeing wood very lightly because my goal is to highlight the grain and not to paint the wood.
DO THE FOLLOWING AT YOUR OWN RISK -- IT IS EASY TO MESS UP A DYE JOB IF NOT CAREFUL:
Another trick that I do when dyeing maple is to very lightly mist the piece with alcohol after the final layer of dye has been added. This works best on highly figured maple and adds a slightly reticulated pattern to the dye treatment. This takes some practice. Less is better when misting. If you like what you see, stop right there because more misting will not give better results.
WARNING -- DO ALL BURNING OUTDOORS.
A quick note to add to Bill's reply- spray the alcohol out doors or in a highly ventilated room. Other wise you will get a cheap drunk from the fumes which could over come you.:eek:
Just my two cents worth.
Gary
Gary
Absolutely. My finishing room is the great outdoors. Sometimes the weather in my finishing room causes me to delay a project, but I never do this stuff indoors.
Jeff,
Your question was specific to soft maple. Sanding prior to the steps above is critical. One tiny spec of tear out seems to grow to the size of a Cyclop's Third Eye when dyed, especially a dark color.
If that soft maple has a little spalt or is otherwise less than perfect end grain, you'll want to use the sanding sealer of your choice. I use thinned Deft wiping lacquer for this and many other tasks in the shop.
