I have had little response, so I am cutting the prices as noted below.
Also note you can buy the VicMarc VL-300 alone for $$2500.00, OBO, the balance of items (kiln separately, as below) for $1500.00 OBO !
The new price on the vacuum wood kiln is now $750.00 OBO.
Due to ill health, I am selling my Variable Speed VicMarc VL-300 Lathe, (picture at left) 48 " bed, about 28 high-quality knives, Robert Sorby, Crown, and others;
1-Oneway Termite Hollowing Tool Package, bit and handle
1-Hollowing Tool Package, bit and handle similar to above, with 3/4 circular bit
NOVA Woodworm Screws
Robert Sorby # 809H 3/4” Oval Skew Lathe Turning Tool Overall Length 16 1/4”
Robert Sorby , 1/4” Wide Bedan”
Digital Kitchen Scale Stainless Steel Food Scale 22 lb 10kg
Wood Moisture Meter
2-Robert Sorby Double-Ended Caliper2
1-SORBY Hollow Master, Full-Sized
1-Wolverine Vari-Grind 2 Jig Only
1-Wolverine Skew Grind Attachment
1-Wolverine Grinding System with VARI-GRIND jig
1-Hardwood Scraper 3/4"
1- 1/2" Robert Sorby #842FLH Fingernail Bowl Gouge
2-sets PSI Woodworking LCSIDE2 Round End Inboard Side Scraper 2pc Chisel Set
1-Neiko 01407A Electronic Digital Caliper
1-PSI Woodworking LCHSS8 Wood Lathe 8pc HSS knives Set (Cheap set of 8 knives for beginners.)
1-Crown Tools 252 / Big Horn 24133 1-1/4 Inch Oval Skew Chisel
1-Nova G3 chuck body & jaws
1-grinder with 180 grit CBN wheel, one stone wheel
1-3 Pcs Carbide Lathe Tool
Several additional custom-made HSS tools
Many other misc accessories and face plates, air-powered face shield/dust mask
Price for all is
Also selling 24" diameter 48" long vacuum drying wood kiln setup, works well, top quality vacuum pump, hardly any use, 2 heat matts, all valves, gauges, timer, etc. #850.00 to $750.00 OBO.
Wood Moisture Meter
