I have drilled a few pen blanks and it seems the exit hole is a bit off center; some more than others. I now use a 4 inch drill press vise from HF (#30999) and try to make sure the blank is straight as possible. I realize that a lot of the material will be turned off the blank but in case I need more precision, what do I need to do? I don't do enough pens to justify the cost of the center drill vise at this time. Maybe I could get one for the wife for our 45th anniversary?
Thanks in advance.
Thanks in advance.
