Anyone have experience with this product?
Odie,
Assuming this is like other reverse chucks I have seen,
It looks like a hollow from turned with a faceplate and a wooden cone of similar color.
Gives the illusion of a wide lipped vase shaped opening on the top of the hollow form hollow form.
The rod sticking out of the head stock has a morse taper on one end and a soft pad or cup on the other end.
The hollow form is put over the rod with the soft pad resting on the center of the bottom
The tailstock is brought up and when tightened it centers. The Pressure from the tailstock goes through solid wood to the pad on the end of the rod.
Pressure can't break the hollow form.
On the left is a wooden cone with a hole in the center the diameter of the shaft. The cone is slid into the opening of the hollow form and a locking collar on rod holds it in place. The cone is just to keep the hollow form from vibrating there is no pressure on the opening.
On the right is the faceplate tenon that needs to be tune way to finish the bottom.
Hope that is somewhat clear.
