As above, It is a hook tool.
An excellent tool for endgrain hollowing.
A short learning curve for most.
My question is why are these not more widely used?
I would definitely second this advice. Tool presentation is different from other tools. Catches with a hook tool can be 'exciting'. But the cut surface can be remarkably clean.All the above are correct, in that it is a hook tool. I would suggest that the learning curve in how to use it can be short - provided you have an experienced user working with you the first time. If you are not an experienced turner already, you can present the cutting edge of this tool at the wrong angle. And the resulting catch can be alarming enough to make you put that tool in a dark corner, or rarely used drawer, never to be seen again.
This tool on end-grain, can give you a very clean surface. Well worth learning how to use it. But start with someone who knows how to use it.
Great advice.All the above are correct, in that it is a hook tool. I would suggest that the learning curve in how to use it can be short - provided you have an experienced user working with you the first time. If you are not an experienced turner already, you can present the cutting edge of this tool at the wrong angle. And the resulting catch can be alarming enough to make you put that tool in a dark corner, or rarely used drawer, never to be seen again.
Thanks. That was an interesting view.
That was a great video. Thank you for posting!!
This shouldn't diverge from Alex's question. What she showed was one version of a hook tool. Google or Youtube shows other tools not exactly like her tool that are also called hook tools.@Doug Rasmussen , at the risk of diverging the thread (although I think Alex may have the answer to her question), perhaps you could give some more info on that hook tool? Tool name? How is it used "externally"? Link to the video?
I'm particularly interested as you say the tool is used flat (no pitch, no roll), so it might be used in an articulated arm hollowing rig.
