Do Over?
Ever wish you hadn't put a piece of the wood on the splitter? This was to be a portion of my night fire, but now I'm tempted to try something with it instead. Nasty radial check in a bad position may prevent getting even a dish out of it, but I think I'm going to try anyway. Perhaps a bit of black epoxy fill will save enough depth for something useful.
If I get some turning time between chores this weekend I'll have a go at an "unnatural edge" shallow bowl or dish. Wish I had the other piece, but I may have already put him up the chimney.
WAY too pretty in the ripple there! With a little imagination there's something beautiful can come from that chunk.
If people saw some of the stuff going into my wood furnace, they would be here with pitchforks and torches - and chainsaws! That would make some nice spindle stuff as well.
I decided to make or break one piece rather than cut it up into small ones. Between Norm/TOH and Roy, here's whats waiting to be sanded after a day or two of step-down. Not all I'd have wished for, but shows promise of salablity.
Think I'll do a wire brush edge to kick away the silver fuzz rather than a char. Have an idea that I might try one of my mini-mops as an alternative.
Now that is interesting! I have done the wire brush thing, but not a "char". How would you go about that and only effect the natural edge?
Charlie M
Char is what it says. I use a little mini-torch to char the edges rather than color them black. Happens before final sanding, which takes care of any overburns. Daub on the first coat of finish or you'll spread the black. http://i35.photobucket.com/albums/d160/GoodOnesGone/Feltmate-Dish-Opposite.jpg
Minimops are sanding devices sold by Klingspor http://www.woodworkingshop.com/cgi-...etween=0&daysBetweenFix=0&monthsBetween=0that do a neat job of smoothing carvings and such without destroying contour. Even my brass brush does a bit of its own sculpting, so I'll give the mop a try on a piece of end scrap from this chunk and see if I like it.
Wood is soft maple, though it was summer cut and kept low in the stack, which sort of spreads the darker color through the piece. It has some spalting, which isn't really a plus here, but often you can ferment the wood without spalt. Smells like wine.
Nice save Michael. Now you will have me checking the opposing wood on every canker also. It will take days to turn a tree into firewood and the pieces will go from 24" to little disks because I will not want to pass up any chances that could be lost. I hate splitting too because of finding my overlooked opportunities. I guess this spring will not be any different.:eek:
char
Charlie M
Reminded about
charing" on this forum a couple of months ago-didn't have a blow torch and was fearful of setting fire to shop. Heard about the micro blow torch-went to home Despot, and bought one for around $30. Have used it on about 20 small natural edged and a couple of larger ones. I first sand edges (220) to get rid of ? cambian fibrous layer, scorch, and then wire brush and then sand to 400 after applying mineral oil for "wet" sanding. I am very pleased with the appearance. Looks natural, but gives a more finished appearance to the rustic piece. Gretch
char
Thanks Gretch. I'll look up the micro-torch the next visit to the city. I also don't like the idea of an exposed flame in the shop. I would take the piece off the lathe and do such an operation outside. (I still get reminded about the burning bowl in the microwave)
Charlie M
