These are the published categories for the annual Florida State Fair woodturning Competition.
The formatting lost most of the numbers. The entrant pick the category, the judge has the option of reassigning categories.
Class Description
(HOLLOW VESSEL) Definition: Hollow vessel – a form with a top opening smaller than the width, containing substantial “hollow area.” Vase – a hollow vessel higher than wide
Standard hollow vessel or vase – may contain decoration while turning on the lathe (i.e. coves, beads, surface texture
Embellished hollow vessel or vase – carved, fluted, wood burned, inlay, colored, etc.
(BOWL) Definition: Bowl – top opening larger than the base, exposing the interior to view. (Wider than
high)
Standard bowl – may contain decoration applied while turning on the lathe (i.e. coves, beads,
surface texture
Embellished bowl – carved, fluted, wood burned, inlay, colored, etc.
(PLATE / PLATTER) Definition: Plate/platter – a form substantially wider than high with the surface open to view.
Standard plate / platter - may contain decoration while turning on the lathe (i.e. coves, beads, surface texture
Embellished plate / platter - carved, fluted, wood burned, inlay, colored, etc.
(SPINDLE) Definition: Spindle – primarily turned between centers with grain parallel to lathe bed.
7. ALL SPINDLE – Primarily turned b/t centers, grain parallel to bed of lathe (NATURAL EDGE)
ALL NATURAL EDGE
ALL SEGMENTED or constructed: pieced together and turned with one or more woods (e.g.
maple/walnut)
OTHER THAN WOOD at least 50% other material (alabaster, plastics, metal spinning, soapstone,
and combinations of above)
MINEATURE no dimension exceeding two (2) inches
ALL ORNAMENTAL (done with an ornamental type lathe)
LIDDED CONTAINER no dimension over 4”
LIDDED CONTIANER any dimension over 4”
OTHER jewelry, toys, pens, Christmas ornaments, utensils, constructed multiple turnings,
resulting in spinning wheels, ships, wheel clocks, candelabra, reassembled turnings, wood or non- woods acceptable; however, 50% of project must be turned.
