I have not turned a lot of green wood and nothing this size approx. 13 inch wide by 6 deep what is the best way to cut these round. Chain saw or Band saw I have a 14" band saw but how do you mark a circle on the bark side or is there a jig I could make
Bill
I turned 1 of the pieces Saturday to basically what looks like yours. The piece was quite wet to the point is was splashing me and my face shield. Once off the lathe I but it in a paper bag and set it aside. Bill is that what looks like anchor seal or something else and should I be doing anything else to prevent cracking
I usually anchorseal just the endgrain areas and sharp edges. This is where the bowl loses moisture the fastest and thats what makes them crack. You need even drying. I also use a paper sack or box with the lid closed but not taped.
Where do you find paper bags? They seem to be more scarce than hen's teeth around here. Anchorseal is still pretty cheap for members of Woodturners of North Texas. Your area is probably much more humid than it is here. Bowls coated with Anchorseal usually dry in three or four months here.. Large thick ones might take six months (based on my experience with one 18" diameter box elder bowl that was rough turned to 1½" thick). Most of what I turn is mesquite or dry maple so I don't need Anchorseal that often.
I have rough turned both bowls now and have put anchor seal on both. I am in Northern Ontario and below freezing for the winter. My shop has 2 sides 1 heated with a pellet stove so it is dry heat with temp set to 50 F at night and up to 70 F while working the other half is unheated but with heat loss from the siding door it never goes below 32 F liquids never freeze how ever humidity would be much higher as this is the side the thaw out my snow machines on. What would be the better side to store the bowls
John,Bill. It's mostly because anchorseal is messy. I just estimate the end grain and over paint. Al. With anchorseal and paper sack I don't have to touch them again until dry. Since I do t turn many bowls I do t worry about how long it takes to dry. I always have lots of dry ones on the shelf if I feel the need to finish turn one
Bill
Frozen food isle at walmart, only one size but better than nothing
Sean,
You want to slow the drying. If the heated side is below 30% RH, I would put the bowls in the unheated side to dry for a couple of months then bring them into the heated side.
The idea is to slow the drying. The anchor seal does this but in super dry space the bowl might still loose moisture too fast.
Relative humidity (RH) is a function of temperature so you can't compare RH at the two very different temperatures when it comes to drying wood. Warm air holds a lot more total moisture before it reaches saturation, so even if the RH on the cold side where the temperature is just above freezing happens to be greater than the RH on the warm side, the wood is very likely to dry out faster on the cold side. I don't think that your snow machine would contribute much to the RH unless it is warm enough to generate visible vapor. If you have a hygrometer, you could see what the RH is on the cold side. Unless it is really high, the warm side might slow down the drying better than the cold side. However, in the real world with Anchorsealed wood the difference probably isn't enough to worry about.
Bill,
I agree is best to use a hygrometer.
It is my assumption that the air inside the heated area and the unheated area both have the nominal moisture volume of the outside air.
The saturation point of the heated area is greater than the saturation point of the cold area.
If this is true the RH of the cold area is always more than that of the heated area.
RH= 100 x ( moisture volume)/(saturation moisture volume)
is there a flaw in my thinking?
