I filled a few knot holes in a couple of roughed out & dried bowls.
In one I used epoxy & turquoise powder
In the other i used epoxy & ground glass
Same brand & ratio of 2 part epoxy for both
The glass/epoxy mixture was perhaps slightly thicker than the turquoise/epoxy. I did it by eyesight. Peanut butter +-.
Anyway, I let it sit overnight & chucked it up this morning. Turquoise went first. I really didn't notice anything out of the ordinary working the piece. Cherry bowl. Should be pretty with some finish on it.
The glass was another matter. The gouge flat out wouldn't cut it. I realized this after dulling 3 different 5/8 gouges. Didn't want to try the carbide easy rougher on it. Those replacement disks are some $$$.
I did a little reading and I find glass rates anywhere from 5 to 7 on the Moh's hardness scale. At 5 it should cut with a steel gouge. 5 is also about what turquoise is. However, at 7 its clearly harder than the steel in my gouge.
Could the heavier concentration of glass or perhaps just the particle size have anything to do with this. I like using the filling- glass is cheap enough, little packets of turquoise will put me in the poor house.
Comments, experiences, or cheap sources of powdered turquoise would be appreciated
Thanks,
Thanks,
