I'm struggling to get cross-grain smooth by sanding. I've tried very light touch with sharp tools without success. I'm open to suggestions and wonder if a cabinet scaper might help with this problem.
John
Some turners use cabinet scrapers quite effectively.
Shear scraping works well for me.
The key to easy effective sanding is a smooth turned surface. This comes with time when you are just starting.
Most native hardwood I sand to 320 then sand the first finish coat with 400
Some tropical like ebony I have to go to 800 or higher not to see sanding streaks because these woods have no visible grain lines.
I most often use 3” Velcro discs on a mandrel in a 90 degree makita drill.
I usually only sand dry wood.
Cut rim Bowls and platters I sand on the lathe. Slow lathe speed, relative fast drill speed.
I sand through 220 with the lathe running slowly 30-60 rpm.
With the 220 I stop the lathe and then sand with the grain with the lathe not running
With 320 just sand with the grain.
If each grit has removed the scratches from the previous grit there will be no sanding marks.
I watch a stream of dust being drawn into the dust collector. New sanding disc is needed if you don’t see the dust stream.
All my hollow forms and NE bowls I let dry for a few days then sand off the lathe.
Hold the piece in my lap. Spot sand with 180 then 220, 320. I do most all of this sanding wit the grain.
