- Joined
- May 16, 2005
- Messages
- 3,540
- Likes
- 15
Been roughing, in this case birch, and noticed that the bevels I was renewing already showed some surface corrosion even after a few minutes working this comparatively low acid wood.
Which makes me think that perhaps my observations that the edge-holding ability of my M2, powdered metal, high-carbon and A2 gouges are pretty much equal when cutting wet wood are valid. The limit is corrosion rather than heat, because I'm roughing wet and pretty well cold-soaked wood at slower speeds.
Anyone else have a suspicion that the true destroyer of edges in this application is corrosive dulling? Owners of other more exotic alloys have different experience? The grind angles on the various gouges are different, but I am normally paring wood under low tool pressure regardless, because I'm hoping to have a good elbow when I eventually reach Dustpan's age.
