Correction to safety stand article in Winter AW
DMcIvor
AAW Staff
Twisp, WA
www.mcivorwoodworks.com
I just spent an hour this morning attempting to assemble the safety stand described on pages 64-65 of the winter issue of American Woodturner.
As illustrated, the instructions in step one indicate assembling the stand from the center of the threaded rods, working outward. The stand elements are shown centered on the rod, starting 11" in from either end of the rods.
Studying the illustration of the complete stand assembly process depicted above step 1, one sees that there are three pieces of ply to one side of "center," and four to the other. Attempting to center the assembly on the rod therefore will not work, as you will end up with excess rod on one end and too little rod to complete the project on the other.
The better assembly method is to start from one end and assemble towards the other. This also negates issues which may arise from cutting the threaded rod to slightly different lengths.
Otherwise, I ended up with a solid little stand that I look forward to putting to use tomorrow.
Central Ohio
Thanks for this timely information. I was reading this article this afternoon and was questioning the assembly procedure. I have most everything I need to make this safety stand. I am planning to make it one day next week but something just didn't look right about the way they said to assemble it. Hopefully this will save me some time and not leave me scratching my head.
Happy Turning
GA Darling
