In March I moved up from the Jet 1642 to the PM3520B. My Dad was in my shop so much I had to give him the 1642 so I could get some work done.
I had been coring with a Woodcut system. The 1642 lacked the power to core with much speed but I got by. The toolpost on the Woodcut Sytem is too short for the Powermatic. Therefore I need to make a decision to make a special tool post adapter or replace the coring system. So here are my questions.
McNaughton: I tried the system once in Provo under the supervion of Mike Mahoney. This goes back 3 years but even with Mike at my side the thing just plain scared me. How long does it take to build confidence?
Oneway: It looks like it works similar to the Woodcut except it has the 'Support finger' for the blade. But the support finger is on a separate post and looks like you have to loosen a bolt to advance it under the blade as you go into the bowl. That part just doesn't make sense to me. Someone explain that.
Right now I'm leaning toward the Oneway if I can get over the How it works question, but I welcome getting talked into the McNaughton.
Got my silly stimulus check from the goverment yesterday and I intend to do some stimulating with it.
Frank
Frank
