Well, green pear cuts like butter. I do have a video up on You Tube about coring with the McNaughton. If the shavings are plugging the kerf up, a couple of things could be happening. Most common is that the blade does not have a perfect curve arc. My guess is that Kel profiles them first, then bends them, so the tip tends to go straight rather than following that perfect arc. This means that the blade ALWAYS drifts to the outside. I have not blistered my fingers yet, but that blade gets hot, and you get burn marks on the wood. The more I open up the kerf, the more the shavings seem to plug up the kerf. I go as far as I can till I can feel the blade binding, and then pull back to the top and take a little more off of the outside of the kerf. This opens up the kerf in the correct, to me, manner. Mike Mahoney "fish tails" as he cores, which means he wiggles the handle back and forth a bit to keep a wider kerf. If I practiced that method, I would be better at it....
As for height of the cutter, I keep mine at maybe 1/2 inch above center to start the cut, and I have an end grail collar to go around the tool post. There is a lot of flexibility built into the system. If you start at level with the center, by the time you get near the end of the cut, you are well below center. Ever try to remove the stub left, with the cutter, when you get to the end of the core? First thing the cutter does is drop 1/2 inch or so on bigger bowls.
Smooth sides help the chips eject. This is why I don't fish tail, and why I come back to the top and open up the kerf on the outside of the cut, not the inside of the cut. Some times, you can reposition your banjo to help the cut go in a little easier. This does remove some of the "pressure" of a bound blade. I will use glide coat on the gates for the blade and some times on the actual blade. The slick stick from Woodturner's Wonders can work as well. You will end up turning all of the stuff off as you finish turn.
The deeper you core, the bigger the drift problem is. Mike Mahoney commented when I saw him at the Oregon Woodturning Symposium 2 years ago, that he cores 95% of the time with the medium curve blade. Me too!
