Congratulations to Gabriel Hoff for "Spalted Beech Round Bottom Box" being selected as Turning of the Week for January 6, 2024
(click here for details)
I'd suggest you apply a coat of SealCoat (a premixed dewaxed shellac from Zinsser), and then sand before staining. This should also work nicely on cherry to prevent blotching if you finish with an oil finish.
The only thing I can add to these good ideas is to keep small scraps of the materials you commonly use and experiment on those, using different techniques so that you don't find yourself with an unintended result That brings you grief.
What are you staining the cherry to resemble? Though it is a very turner-friendly wood, I think it should stand on its own, rather than be colored to resemble something else.
The way to control pigment penetration/distribution is to use gel stains.
