I've been doing a little checking around, and found the MOHS scale of hardness and compared hardened steel to aluminum oxide. The aluminum oxide rates a 9 out of a possible10 and hardened steel rates aroung 7 or 8 out of 10. They are fairly close, but the AO is harder by a small margin.
Material
Mohs' Hardness
Alumina (Synthetic aluminum oxide)
3.4
Aluminum oxide
9
Alundum (Fused brown Al203)
9.0
Amalgam
4 - 5
https://www.reade.com/reade-resourc...perty-briefings/32-mohs-hardness-of-abrasives
The point of this, is I feel many turners use their sandpaper for much longer while sanding, than they would for their typical turning tool.......when the difference in hardness isn't that much.
Sandpaper, as well as turning tools give a false impression of sharpness when you run your fingers over the cutting edge to judge how much life you have before tossing the paper......or resharpening the turning tool.
When we learn to sharpen sooner, and toss used sandpaper sooner......the benefits of doing that are great. It's hard to come to doing that with sandpaper, because it'll still sand......just not as effectively. The same applies to the turning tool.....it will still cut, just not as cleanly.
Material
Mohs' Hardness
3.4
Aluminum oxide
9
9.0
Amalgam
4 - 5
- Steel – 4 – 4.5
- Iron – 4.5
- Palladium – 4.75
- Rhodium – 6
- Titanium – 6
- Hardened Steel – 7 – 8
- Tungsten – 7.5
- Tungsten Carbide – 8.5 – 9
