colorless finish
Mineral oil is a treatment, not a finish. No resistance to anything save (temporarily) water is conferred by applying. Clearest would be lacquer, or maybe super blonde shellac, depending on what you need a finish against. Think you might want just the touch of amber that super blonde would give. I don't like the acrylics.
Soft maple.
Any options other than mineral oil for clear finish on birdseye maple. Don't want the "plastic" type options.
Hi Charles,
If you're seeking a true "water clear" wood finish, you're going to be looking at the quality waterborne acrylic lacquers and polys. "Quality" in this context rules out anything you may find at a big-box store because of the film specs that will often push reflected/refracted light into the blues.
The problem with all waterbornes is, of course, raising of wood fibers. You can lessen or eliminate this with a very light application of bleached (Ultra Pale) shellac or an application of artist's fixative such as Krylon Matt Finish or Workable Fix-a-tif (both rattle-cans) before applying a more substantial coating. I find that the Krylon is often enough in and by itself for display pieces such as the Box Elder jars pictured. With a couple of light coats it will produce a very nice sheen when dry and rubbed down with 4-0 wool. (see pics 1&2)
Once sealed, you can take your finish "deeper" of you wish. My most-used finish is General Finish's Enduro Clear Poly that will remain water-white. It can be applied by brush, wipe, or spray, although I prefer spraying, and has 100% burn-in between coats applied in the 4-6 hour window. It self-levels very well. After curing it will rub out to whatever gloss you choose so a pair of light coats will definitely avoid the "plastic-dipped coating" look so common with cheaper finishes. Look for it in the range of $24/qt., $65/gal. The pictured small blue urns have done well with this application over dyed maple burl.
