The forum upgrades have been completed. These were moderate security fixes from our software vendor and it looks like everything is working well. If you see any problems please post in the Forum Technical Support forum or email us at forum_moderator (at) aawforum.org. Thank you
Congratulations to David Wyke, People's Choice in the February 2026 Turning Challenge (click here for details)
Congratulations to Michael Nathal for "Eroded Wheel" being selected as Turning of the Week for March 23, 2026
Is there a chance that its just left over sanding dust? Try cleaning with a dry rag or with compressed air, if you have it.
I don't have personal experience with acrylic pens, but I know some have had good success with sanding using micro mesh pads up to 10000 grit directly after turning instead of applying CA glue
The only reason that I can think of for using cyanoacrylate adhesive on an acrylic pen is to fix damage such as bubbles or chip outs. As far as sanding and polishing are concerned, both CA and the acrylic pen material seem to polish out about the same so I can't see a reason for applying CA as a top coat. Besides that, there is a possibility that the CA could damage the acrylic by softening it. No all pen blank plastics are the same. Some might be fine with a top layer of CA if that is important to you. Sometimes Inlace and "Cactus Juice" are used to encapsulate materials that might occasionally have small air bubbles if the vacuum process wasn't done well enough. I think that it is OK to apply CA on those plastics, but if I were you, I would verify that before proceeding.
