Coffee Mug handle and Teapots?
Maple Valley, WA
I have made a coffee mug and would like to put a traditional handle on it. I assume I can cut one on the bandsaw and sand the edges but then I do not know how to attach it securely to the cup body. Anyone have any suggestions as to the handle construction and/or the attaching?
Also while im thinking about it, are there any good tutorials for making these teapots I see all over these days?
Handles are something I agonized over for quite a while, till I figured out a simple way to do them.
First, turn your vessel, but leave it mounted on a waste block or in your chuck. Then assemble and make your handles.
Second, get some pressure sensitive sandpaper...the stuff with adhesive on the back. You can get rolls of it really cheap at Amazon. Cut some strips long enough to wrap around your vessel, or several pieces, if the vessel isn't a perfect cylinder, and attach them to where the handle will contact the vessel wall.
Third, attach the handle to a sturdy support of some kind...either a flat board, or a jig that can hold it steady. Then turn your lathe on slow speed, and hold the handle up to the spinning vessel. The sandpaper will (eventually) sand the handle ends to perfectly match the curvature of your vessel.
Finally, remove the sandpaper, and apply a dob of epoxy to the ends of the handle...not much, just a tiny amount...and attach the handles. I use 5 min epoxy, and need to hold the handles in place till it sets up.
While sorta crude, this technique has worked very well for me. The resulting joint is a perfect match, and the glue joint is stronger than the wood.
Be sure to straddle centerline with your handle for best results if you use Dick's method.
Another is to carve or file flats in your piece to take the handles and glue them on without modification. Be sure and do the sanding inside the handle before you attach. They break easily if you're trying to do it after attachment.
Thank you for the tips, Dick that is just brilliant. I will post some pics when I finish it. I have a series of boxes I am wanting to finish but it will be done shortly and then on to finish my cups. Thank you again.
