CNC details
Sandpoint, ID
I’ve a question for you. I happen to have a CNC with a lathe in addition to my VL 300. The photo is of the urn I did for my parents, with the engraving and carving done on the CNC.
I see some of fine work on this site with textures and embellishments of a variety of styles and wonder about using the CNC. But—
That seems to destroy the value of a hand turned piece.
Nothing wrong with using CNC - my only issue is/was with those who'd try to call CNC made items "woodturnings" but I see nothing wrong really with embellishing or augmenting turned pieces with CNC work. Your Urn looks really nice, and it's fairly obviously a segmented turned box/urn. Whether the lid embellishments were done by CNC or Hand carved or router (or Rose engine lathe, for that matter) they're still quite nice. Only thing that irks me (Gets my knickers in a twist) is when a piece of work is presented as woodturned, but done on a CNC (or incorporating very little, if any actual turned pieces) - They're art, sure... they look pretty , yes.... but to put them out there to compare to a piece turned on a lathe (by an actual person hand controlling the tools by their own skill, instead of by machinery) just rubs me the wrong way.
If you can do your embellishments or texturing of a turned piece with a CNC, Router, Laser, Rose Engine, Dremel, what have you, if it adds to the appeal of the piece (bearing in mind one person's appeal may be another person's idea of ugly!) then I see nothing wrong with it at all.
My experience with the CNC is there are real restrictions. And, with a little practice, one could probably hand carve, engrave, texture, faster than programming a CNC to do it. Now, if you had hundreds to do, that’s another story.
I would guess that that is because the CNC's you are familiar with really aren't designed for embellishing turned pieces. In making the LatheEngraver, my goal was to convert the lathe itself into the CNC machine and removing those restrictions. It has been complicated (mostly from the software side), but it has developed far enough that I would say it is significantly faster to "program" (create a design in CAM software) than it would ever be to do by hand. @Jeff Struewing has been helping me with project, and he can make new designs for the lanterns he makes in minutes.
Yes, the problem with my CNC program is that you are restricted to wrapping around a cylindrical shape, and at least I am not aware that it is possible to do what you are doing.
the other thing that has been an important motivation for me personally is the difficulty I have with hand-carving. @Rusty Nesmith has me beat, because I only have C5-C7 fused in my neck, but the motions associated with hand-carving really aggravates the already damaged nerves, though it was worse before the fusion. I don't get any of that same strain designing something on the computer.
Do you mean value of the piece or value of the making.
Regarding the piece - it is what it is - maker knows the process used to make it.
Pieces stand on their own.
The making - thats a decision for the maker.
I enjoy locking in the bevel and shooting streams of shavings off the tool. I wouldn’t get that feeling watching a machine work.
There is also skill and enjoyment to be had in making a CNC do something no one else has done.
I look at the urn and I can't be 100% sure whether it was hand turned or CNC'd. But I look at the engraved name and it seems obvious it was not done by hand carving. It's not a font style a typical carver would use. And it's too perfect.
If you wanted to make the name look hand carved a stick font might be a better choice. You could hand draw the name, load that image into your CAM software to cut and make it look hand carved.
As someone that designed injection molding tooling and then actual products I'll offer a few points to consider.
1. CNC is nothing more than cutter control. Yes it is automated, but there is an art to cutter selection, cut parameters and setup (the last being the easiest to learn).
2. Designing the shape of objects gets easier with time. I taught CAD design to mechanical engineering students in college. Given a little time any shape that can be imagined can be designed in a computer. It's a thought process in how to get the art in your head into the computer. Much like doing the same at the lathe by hand. In fact that is one method of modeling i would use to teach a turner to build their models at first. Take block A, derive shape B to spin and cut out next shape.
3. With practice modeling can be quicker than you think. The biggest trick to it all, for embellishments, will be to get your hand turned design into the computer. If you have digitizing equipment this because slightly more trivial.
4. By introducing imperfections into a CAD model, it could be made to be indistinguishable from hand work.
With all that said. The tools you use to create your art doesn't dictate if it's art or not. I struggled with this a lot in my mind. When someone would say what you've done is art I would say how it's all mathematics, it's defining shapes for a purpose, a function, with what it looks like last. But what is a bowl, a box, anything that is turned (for the most part) no different than objects i designed (although a lot simpler in geometry).
So feel free to say you have CNC Embellished hand turned pieces. Use your process as part of your story. The art is getting what you intended to emerge from raw materials nature had given us.
Gregory
Ps. You made a beautiful urn for your parents.
Is this something you are thinking about. While not woodturning per say, cue makers use CNCs to cut inlays that wrap around cues. There is basically a programable lathe type of set up that will rotate the shaft while the CNC spindle cuts the grove. While you probably aren't thinking of inserting inlays, it really wouldn't matter as you just program what you want. Nothing says you couldn't add inlays though.
View: https://www.youtube.com/watch?v=MACCtalX2ck
Starts about 3:15
Depends on who you are trying to impress. Yourself and the general public could care less about CNC. If you are turning to satisfy other turners, you will get kickback.
I have a CNC as well as a lathe. I make a lot of small 4" boxes with an engraved lid on the CNC. These are flocked and marketed as small jewelry box. When at craft shows I make sure to distinguish these from the turned bowls / boxes that I also make. The only reason I do them on the CNC is I can take a larger board and cutout out 6+ at once. While this is going on I can spend time at the lathe doing more "artistic" boxes / bowls. The items are also priced in the manner they were made. The CNC boxes are a lower cost than a similar sized turned box. I often get asked about that and I am upfront with the customer stating this was made on a CNC and this was turned by hand on a lathe.
CNC somewhat is an art form in itself. Alot more to it than some make it out to be, especially if you want to get past the basics. I have no problem with some including cnc work in with their woodturning if it adds something not attainable with standard woodturning.
Just as a you can make an ugly wood turned piece that resembles a spittoon, you could also make an ugly cnc embellished woodturning piece. There is more to a good turned piece than just turning wood out of it, or using a cnc to help accomplish your end result.
I'll have to look this up. I love reading about modifications/adaptations people come up with.
Gregory
I'm a couple of days away from opening the website.
You can see photo/video documentation of the project here.
I look forward to seeing more! I have been toying with the idea of mounting my xtool laser, using my lathe as a rotary adapter. Looks like you have gone allll the way down the rabbit hole!
