I had some time this afternoon so I finished the inside of the bowl.
The bowl wall thickness is about 3/64" (.050"). The thickness is consistent in the curved portion, the thickness does not increase toward the bottom.
The moisture content measured on the inside just off the lathe was 22%. The outside was a little less since it dried a bit overnight after turning 24 hours ago.
According to an article in the archives this should dry without cracking given its thin section. Two five second runs in the microwave brought the moisture content down to 16%.
Picture shows after the final turning using a carbide tipped boring bar. A 1-1/8" collet is holding it on the spud on the bottom.
