• March 2025 Turning Challenge: Identical Bowls or Plates! (click here for details)
  • Congratulations to Michael Nathal for "Ash Ring" being selected as Turning of the Week for March 17, 2025 (click here for details)
Chuck thread
Worcester, MA
I'm returning to my lathe (see my intro today) and am having misgivings about using my 4" chuck. I want to turn a baseball bat with my son-in-law and tried it using the spur and live center and the blank blew apart. So i decided to use my Delta 4" chuck that I have had for 10+ years and probably haven't used it (or the lathe) for close to that. When I went to use the chuck, I was not able to get it to mount all the way on the 1" 8 tpi spindle - or so I thought. The face plate screws on 100% of the threads. A pic is below.
My question is - is this the proper way for this to sit? It won't turn any further onto the threads. I bought new chuck (Deefiine 4" with a 1" 8 tpi thread) and got the same result. Appreciate any feedback you can offer.
It doesn’t look right to me. Be nice for someone to examine it in person.
I’m not familiar with that chuck. I suspect someone here is. Do you have the chuck model number?
Have you used that chuck on that lathe before? If so, do you remember if it fit better then?
I’d do two things: measure and count the threads on both chuck and lathe to make sure they match. (Harder for internal threads but possible.)
Check the threads on both for damage.
I’d also prefer to use a chuck but the centers should work. Maybe describe the steps you used to mount the blank. There are a few ways. Is the drive center a 4-spur type?
Is the blank square or round? What kind of wood?
How did the wood blow apart? Chunk came off, grain at an angle? Split down the length? Fly off the lathe?
What tool - spindle roughing gouge, sharp, large? Did you get s big catch?
The Delta chucks were the same as Nova G3 chucks, as far as I recall. They were decent chucks, but may have been made specifically to fit Delta lathes of the era, and it's conceivable they won't screw fully onto a Jet lathe. The base of the chuck really needs to fit solidly flush against the face of the spindle shoulder. Rick's idea is a good one, but I don't see anything sticking out far enough for a set screw to go into.
BTW, you need to step back and consider why the bat blank blew up. Between centers is a very feasible way to make a bat. Putting one end in a chuck will not address whatever the issue was with your first attempt. I strongly urge you to figure it out before you try again. Your safety depends on it.
What @Dean Center said. Check the thread depth of both. A thumb on a pencil will be close enough to. Tell you if the spindle threads are bottoming out. If it isn’t bottoming out, check the threads for burs or deformities.
Between centers would be my choice for mounting a bat blank. Unless you had turned it quite thin- “blew apart” would lead me to think you had a defective blank, cracks in a solid wood blank, or poor glue joints in a glue up.
If the tailstock moved or the hand wheel opened up the blank could come free on the tailstock end and beat itself against something possibly splitting the blank. Turning between centers needs a tailstock that locks in place and locking the quill so the handwheel dosen’t open
Consider turning a few mini bats for practice. Use a 2x2x12.
Tool handles
Gavels
I would do some small stuff before turning a Roy Hobbs wonder boy.
Thanks everyone. The practice wood was a 4' long, round bass blank. The real bat will be hard maple. The tool was a roughing gouge. As we got to the handle (the thin end) the pressure caused the piece to break or snap. I feel that the gouge was not sufficiently sharpened. I have since bought a CNB wheel and will try to improve the sharpening. I use a Wen variable speed grinder. I have a 1" skew but I am not 100% comfortable using it. I have since bought some 12" square maple blanks from Bell Forest and will practice on those.
I have backed off the set screws.
I don't understand why the face plate installs fully, but the chuck won't. Both are 1" 8 TPI.
I don't believe these were glued up. They were sold as billets for bats. The billet was warped and was a challenge for the Jet-Mini at medium speed. We use a centering jig to mark up the blank for mounting. I didn't use a punch to assist in setting the spurs.
The spur is a four-spur type.
Thanks for the feedback. I'll return the new chuck and try to figure this out.
d
Some people using a drive center with spurs will make shallow saw cuts into the wood for the spurs to fit into. A band saw or hand saw will work. Can drive that way without using as much pressure from the tailstodck.
Is “bass” basswood? That can be really soft and not strong. Might need to back off on the tailstock pressure whether using a drive center or a chuck. (after you get your chuck issue resolved)
How did you mount a 4’ long wood blank on a Jet mini lathe?
Sometimes to see where mating surfaces (like morse tapers and threads) are warped or binding we will color the surface of one and see where the color rubs off. I brush on Dykem Blue for this, but even a magic marker might work. Threads can be distorted and still look ok.
If you know another turner in your area with a 1”x8 lathe (or a Woodcraft or other store) maybe you could take your chuck and faceplate and try them on the other lathe and vice versa, ask them to come to your place and bring a chuck.
Tools MUST be sharp. If learning to sharpen, an experience person could be a great help. Are you a member of a woodturning club? There are always people at clubs ready to assist.
How did the depth of threads on the new chuck compare to the length to the threads on the spindle?
On thing that I do occasionally is run the lathe backwards ( by hand or at show speed) with a pencil lead in the threads. A couple of passes cleans out dirt in the thread grooves and may add a bit of lubrication.
Brian, is there an internal shoulder on the chuck that stops it from threading further onto the spindle? Do some measuring on both the chuck and faceplate to see if there’s a difference in how far they can thread on.
I feel like a piece of the chuck is missing... Is this a chuck that supports interchangable inserts? If so, it is possible you are missing the insert? Also, is there any chance that there is a missing collet for the lathe? Something that would take up that space there between the shoulder of the spindle and the chuck? In any case it does look odd. "Wrong" as John said. I have a Record Power chuck that supports many different inserts for different size spindles/threads. Its easy enough to leave that off and forget it, if its been removed...
I’m not sure what is going on with your chuck and agree with others it is not right. I don’t use spur drives anymore. I use either a safety center or steb center. One thing I do regardless of the type of center, I lock the spindle and try and rotate the wood back and forth by hand, tighten the tailstock and repeat several times until it is very difficult to rotate back and forth. Generally I can finish rough turning without having to
re-tighten the tail stock.
A "spur" drive could be the square drive with sharp pointed corners on it that Nova produced. Not chisels at 90 degrees, but actual points. I have a bed extension on a Jet 10X14 mini-lathe, and there's still no way to get a 4' blank on the lathe. It's also way to heavy a chunk of wood for the DC motor to manage. Lots of little things here that would be quickly sorted out with a visit from a local club mentor/coach.
Brian, I would strongly urge you to spend a little time with such a person from your nearest club, and knock some rust off as you resume turning. You can find the club on the AAW's main web site (woodturner.org), click on "Chapters" and select "Find a". (Looks like Berlin is the closest, but there are multiple clubs within an hour of Wooster)
Thanks everyone for the feedback. I'm sending back the Deefiine chuck back to Amazon. I'm troubled that I don't know why the chucks would not mount while the faceplate would. Everything appears to be 1" TPI (English) and I have cleaned all of the threads. I'll use the spurs to mount the maple billet and forego the chuck. The length must have been 42" as that's the max length the Delta bed extension permits. I'm focusing on sharpening my roughing gouge and skew. I'll get back with the results.
