• March 2025 Turning Challenge: Identical Bowls or Plates! (click here for details)
  • Congratulations to Ethan Hoff for "Zigzag Basket Illusion Platter" being selected as Turning of the Week for March 10, 2025 (click here for details)
center rotten part 2
Martinsville, VA
well we spit in the ocean and ran from Noel, so i'm feeling my way through this piece of rotten cherry
only regretable thing so far is the rough log was cut a tad over 12 inches and i had to keep moving tool rest twice as much if i had made the rough log
11 inches
it should start to get interesting this afternoon:D
opps!
well i need some advice on this shape, deminsions were 10 x 6 1/2 and as you can see i have gone thru and the end is still 1/2 inch thick
i tried to go wide as i hollowed instead of boring 3 inch center and then going wide because of the rotten area (a tip from previous post thanks)
the rotten area did not really make any difference in turning this piece, i could use any pointers anyone feels that will help:confused:, it was fun to do just not very successful the first time:D
Hmmmm. Dual axial turning. Not sure where to take it from there Charlie. You could round the whole piece out as mounted and end up with a very interesting spherical vase. Past that, not sure what to suggest.
Dietrich
I'm not sure what you had hoped for as an outcome. I do "angel wing" types like www.aroundthewoods.com , but yours looks like you're trying to leave a continuous circular top, something I've never been clever enough to come up with in my planning. Might give it a go, if you've not decided to copyright the idea. You'll have to trim back the feather edges where you turn through to something fairly regular in thickness if you continue.
well i have seen oblong shaped hollow forms usually with some type of pedistal holding it up with some type of top, i just need to work with the form a little more, this piece will be set in the corner to remind me of how badly my first attempt was, the piece was a failure but i have learned i hope something and am planning the next attempt:cool2:
i am not planning to copyright this, in fact i am trying to duplicate others oblong hollow forms that i have seen
