Congratulations to Scott Gordon for "Orb Ligneus" being selected as Turning of the Week for January 20, 2025
(click here for details)
Does anyone know where one can purchase replacement points for drive centers? I have several, from different manufacturers that have these missing. Thanks, Rick
Since there are no standards for them, you will likely have to get them from each manufacturer. The only aftermarket ones I have seen is Cyndi Drozda does make some for Oneway/Jet live centers
Akshoelee, the Oneway uses a standard taper pin available from the hardware store. (I forget which size.) All you’d need to do is cut it to length and grind the point.
