• Congratulations to Alex Bradley winner of the December 2024 Turning Challenge (click here for details)
Celtic Knot Goblet
SE Kansas
Thanks to Curt Fuller for the instructions. My first attempt and I was off on the glue line but decided to turn it anyway for practice. Primary wood is Maple with Osage Orange inserts.
Garmar,
Thanks for posting. I really like the contrast level between the two woods. It's not so stark as the usual maple and walnut combination.
By the way, is it pronounced Seltik, or Keltic. Have heard it both ways.
Gamar,
That is a wonderful job. You say that you made a mistake on a glue line, but it doesn't show in the photo.
BTW the correct pronunciation IS Kel-tic. Sel-tic is an Americanization usually referring to a basketball team. 🙂
Thanks K-Bob and K-John! So they were really the Boston Keltics.
Meanwhile I still like the contrast level in Gary's piece, and respect his admission that maybe one of the joints is imperfect. It's a very attractive turning, and will bet that the next one will be even better.
Nice looking goblet. I particularly like the symmetry of the upper and lower stem transitions. They always seem to look better that way, IMHO. BTW, what are the dimensions and finish?
You showed a view with two of the inserts mis-aligned, and you said you were "off on the glue line." Two possible sources of this anomaly: The blank shifted for one of the cuts; or your insert thickness didn't match the saw kerf. Which one?
Joe
Misalignment of the glue line was my problem, I have to devise a method of stabilizing the blank in the glueup phase. The Goblet is approx. 4" H x 1.5" circ. Thanks for the comments.
Cutting and glue up are straight forward and I used Titebond yellow glue. Still working on a jig of sorts to assist in the glue up. I usually wait an hour or so for the glue to set before recutting and then let the finished glue up set over night before turning. Not a rule, just what I do. The MASTER of the Celtic Knot Goblet is Curt Fuller. He has the answers.
Neither instructional link is working for me. Is there something I'm missing.
Great goblet! I'd like to figure out how to adapt the technique to some of my own stuff.
