I needed to cut a Hunter tool in half to really look at the cutting angle. I could not do it with my Dremel and a cut off wheel. Well I probably could have, it started but was going to take forever and would not have been straight. So I thought, why not grind it down. I went to the CBN wheel and ground it down to the middle so it looked like it had been sliced. I was worried it might damage the wheel. It is a 180 wheel from Dway. I dont think it damaged it but it sure seems smooth now. Maybe it's a 220 wheel. Still cuts well.
then I bought a set of Harbour Freight Carbon steel tools for $20. I wanted to see if they were any good for beginners and how much I would have to change the grinds. Surprisingly the grinds weren't terrible right out of the box. I'll be making a video showing what I did. Anyway I rough ground them on a Gray wheel and then did more shaping on my White Aluminum oxide wheel. The for final shaping went to the CBN. Totally forgot that they were High Carbon Steel. I did test the hardness with a file before I started and it just about skated across so they were quite hard. Maybe that's why they didn't damage the wheel. Either that or my now 220 wheel just won't clog because it's too fine. Anyway thought I would start a discussion about using CBN for other kinds of steel.
Here is the Hunter tool sliced. You can more easily see the cupped cutting edge and the tapered hole in the middle.
