so why hasn’t anyone developed a bowl gouge made with/of carbide that stays sharp like carbide scrapers? Seems doable.
didn’t know that.HSS turning tools have microscopic carbide particles embedded in the steel so you get much of the wear resistance of carbide without the prohibitive expense.
I suspect the thinking behind Woodcut gouge tips. Is that you cant harden HSS to its maximum for the best edge retention, as due to the length would make it susceptible to breaking. The short gouge tip allows for maximum hardness an much better edge retension.didn’t know that.
The reasoning offered is appreciated. Sharpening is (now) no big deal but my mind was just meandering. Seems like gouges have progressed re holding an edge—HSS steel, for example—and I wondered if carbide would be a next step.
There is a narrow range where it could be feasible. But certainly cost is a major issue and also the method of sharpening you would need a totally different grinding set up. Many of the other issues can/could be addressed quite well. Neil Strong and have been are looking into this and several other options.The Hunter's tools essentially do what you are looking for. If you are asking about a carbide tool that looks like a bowl gouge, there are many reasons why not. A few that immediately come to mind are:
Other than the multitude of drawbacks, it's a great idea ... seriously ... but just isn't a practical idea.
- There are probably nearly as many "favorite" edge profiles as there are professional woodturners
- A carbide profile can't be changed
- Even just a carbide tip would be prohibitively expensive
- Carbide is extremely brittle so an entire carbide bowl gouge would be hazardous
- Without specialized equipment, carbide couldn't be sharpened
- What's the problem with sharpening HSS bowl gouges? It's quick and easy.
- HSS turning tools have microscopic carbide particles embedded in the steel so you get much of the wear resistance of carbide without the prohibitive expense.
- If you've ever dropped a solid carbide router bit, you know not to look down ... it will only make you cry.
Neil Strong has been looking into this and several other options.
I think you would have to sharpen it more often than you think to have a really keen edge.
I will report here at some stage on the forum more fully on my test results on the performance of TC compared to various HSS bowl gouges steels, but here is a preview of the results from a test run on a mid-range Eucalypt...
Correction on the nomenclature, "V10" should be "CPM 10V" only if you know the steel is from Crucible (Thompson tools). Otherwise, you should use the generic nomenclature "A11".
The only generic term for CPM 10V steel is either 10V or A11. I have never seen it referred to as V10.
I too use a Hunter Hercules #3. I really like it and use it just as often as my bowl gouges now.As Bill mentioned Hunter carbide tools will fill the bill. I use them in conjunction with my Thompson tools.
just bought an Osprey but haven’t played with it yet.The Hunter's tools essentially do what you are looking for. If you are asking about a carbide tool that looks like a bowl gouge,
Doug Thompson has made 15V tools, what we found was that 15V steel can be chippy (little chips at the cutting edge). I do on occasion use my 15V 5/8V gouge with the most difficult woods and I for the most part I'll agree that it does a little better than 10V in most of those cases. ............ As far as normal woods that most turners have available to them and use I find no advantage of 15V over 10V.
That's interesting. I was getting little chips like that on my Thompson 5/8 BG ground 40/40 (mostly taking bigger cuts roughing). I went to 45 edge and have not seen any more chips.(little chips at the cutting edge).
