I am looking at getting a hollowing system, several models out there, but I also see two main types the captive system like carter and the flex arm like elbow2….any thoughts on pros and cons?
Hello Richard,I am looking at getting a hollowing system, several models out there, but I also see two main types the captive system like carter and the flex arm like elbow2….any thoughts on pros and cons?
Hello Richard, glad to hear you are thinking about doing hollow forms.I am looking at getting a hollowing system, several models out there, but I also see two main types the captive system like carter and the flex arm like elbow2….any thoughts on pros and cons?
There is some truth to this. With the straight and bent swivel assemblies Jamieson has, flat top forms are easily done, except for a “dead space” area from ~1” to ~ 2” from the edge of the hole. It can be difficult to get the right combination of bar/cutter arrangement to get equal wall thickness. I made a 1/2” bent bar with a carbide tip to get the area around the entry hole out to ~2-3”. For smaller forms I only use this diy bar. For larger forms the swivel assembly allows access to the shoulder area.The articulated is better for more squat forms with a small opening and wide nearly flat top surfaces. Captured is better for tall forms with little undercutting. Yup, I have both.
I have both. With the articulating arm, I stand at the end of the lathe with the tool at my hip. With the captive system, I stand in front of the lathe and push/pull with my arms. I feel much more strain in my shoulder with the captive system. Maybe you could stand at the end with the captive system also? My articulating system has a vertical pin for leverage so you can push with your hip against it. My captive system does not a pin, thus your shoulder applies all the outward pressure. Bar thickness determines how deep you can go on either system.I am looking at getting a hollowing system, several models out there, but I also see two main types the captive system like carter and the flex arm like elbow2….any thoughts on pros and cons?
How bout this one?There is some truth to this. With the straight and bent swivel assemblies Jamieson has, flat top forms are easily done, except for a “dead space” area from ~1” to ~ 2” from the edge of the hole. It can be difficult to get the right combination of bar/cutter arrangement to get equal wall thickness. I made a 1/2” bent bar with a carbide tip to get the area around the entry hole out to ~2-3”. For smaller forms I only use this diy bar. For larger forms the swivel assembly allows access to the shoulder area.
Bar
10” flat top
Thank you for mentioning my system Donna! Coming from you means a lot...You have a lot of options for hollowing. Lots. And of all of them, the best one is one you can use safely and comfortably. I have both the Monster system that Bill Blasic has (no longer available), and Lyle Jamieson’s system. I use both, in fact used Lyle’s system this afternoon to hollow a couple cherry vessels.
My decision in which to use is determined by depth/size of vessel. If the piece is going to be 6” depth max or less, the Monster. Anything deeper than 6” will use Lyle’s system. I have the standard bar and jumbo boring bar. I can’t recall the deepest vessel I’ve hollowed, but probably 12”. I don’t have a steady rest for hollowing to use on my Robust, so I haven’t pushed that depth. For what it’s worth, set up is a lot faster (for me) using Lyle’s system, if that makes any difference.
If you belong to a club, (and that is just one of many reasons to find one), you can probably find a few different hollowing systems to try out. Hands on with an experienced user is one of the best ways to help you make a decision.
