I had a tree taken down yesterday that was at end of life. I had the trunk cut into several sections. The second two photos show the ends of one of the trunk sections. You can see where the wood has separated around the circumference of the section. There is also a weak area across the middle.
It looks like this piece could make some really nice looking bowls but I’m not sure of the best and safest way to cut blanks given the flaws. The best thing to do seems to be to cut the section on either side of the seam across the middle to eliminate it. What about that separation? I’ve thought of cutting it in 1/2 across the center line and seeing if I could split out a blank along the wood separation to produce two blanks, similar to using a bowl corer.
Any ideas on the best way to handle this?
Thanks,
George
Thanks,
George
