Congratulations to Paul May for "Staircase Study #1" being selected as Turning of the Week for November 11, 2024
(click here for details)
Any tips on keeping the ca glue from sticking to a face shield? I sure don't want to get that horrible stuff in my face, but it does ruing a face shield pretty quick. I was wondering if those stick on sheets that race drivers wear would work?
John, I have experimented using saran wrap or similar stretch wrap products from the kitchen. My problem was preventing scratches on plastic safety glasses. I think if you stretch the saran wrap tight over the face shield it will be invisible yet protect the surface.
Hello from Olympia.
Ive had the same problems, happens when I tried to fill a deep void with CA to prevent parts flying off. If you dont leave it overnight the CA inside may not have cured and will splatter you as you cut into the wood.
I like spraying with Stickfast. I also have a piece of luan about a foot square that I hold on an angle in front of the piece and leaning a bit away from me to catch splatter when I first turn on the lathe. I also have an old inexpensive face shield I use for CA use.
Vicki
