Tabitha,
You have several tools available that should make this easy work. With a chainsaw you can cut the burl off of the main trunk of the tree or you could load the log with burl onto your saw mill and roll the log around until you get a good cutting angle to slice the burl from the log. Once the bottom of the burl is exposed you will have a better idea as to the condition of the burl wood grain inside. Some burls are solid and others can have voids and rotten spots on the inside, each one is different. Depending on the planned use of the burl you can remove the bark in several different methods if desired, some people use a pressure washer, wire brush, compressed air, media blaster etc.. When cutting the burl from the log you can leave an inch or two of the log attached to the burl this can provide material to mount the burl to a face plate or chuck maximizing the burl use. The bigger burl might be worthwhile to just cut the log on both sides of the burl and inspect to see how far the burl grain extends into the log. Most burl grain starts at the log surface where the tree incurred physical damage and the tree responded with abnormal growth to close the damage.
