I just took a tour through Odie’s pictures of his shop, and came across the dedicated buffing station he made with the old motor from his lathe. I’m inspired! Odie, has it worked for you the way you’d wanted? Anyone else have a similar setup? I have a motor I’ve kept from an old industrial fan which I bought a 5/8” flange for a number of years ago, thinking I’d make it into a grinder, then thought better of it and bought an actual variable speed grinder. Imagine that! Now I see a use for this motor, and wonder if others have done similar. What size wheel? Any improvements you wish you’d made?
