Buffing Arbor Question
I was wondering who sells a good buffing arbor - I called Stew Mac but they are out of stock and not sure when they will have anything back in....
Anybody know another source to consider ?
Patrick thanks I already have Don's lathe system but i wanted to make my stand alone work but having troubles with it.
I put 12" wheels on it - Baldor 1/3 hp with 1725 and 3450 but it gets hot quick and shuts off. Im thinking its the wheel and im not sure i have the right mounts. See pictures below - i used the arbors I had laying around and they seem to work fine and the wheel spins good and straight. So because of the heating problem im thinking I may just need a higher Hp unit.........
You're swinging a lot with that 12" buffer. If you press much, you'll certainly load the motor, but it should do fine under light load. If you want a better arbor, might want to go with something like this. http://www.midlandhardware.com/Moto...-in-Motor-Shaft-12-in-Right-Hand_p_67740.html Comes in right and left, and with a bushing, will do 1/2" shaft. I used an old 1/2 horse double-ender for quite a while, but now I have the big JET sander/buffer, and love it. A full pony more, not that it needs it for buffing. Pneumatic sanding, perhaps.
I've got the same reaction as MM on this........
1/3hp and 12" buffing wheels is a combination that just isn't going to work very well.
When I first started using buffing wheels, I used an old 1/3hp motor I had on hand. It worked, but bogged down very easily.....and I was using the 8"
Beall buffing wheels.
I'm still using the Beall wheels and compounds, but am now using a 1 1/2hp motor I had when I converted my lathe to variable speed. This is way too much power, but in this case, more power than you need is much better than less power than you need. I'd say the best motor for buffing would probably be in the 3/4hp to 1hp range.
The largest wheels available from Beall are 8". To tell the truth, I've never used anything bigger than that......so, if there is any advantage to larger wheels, I'm unaware of what that might be. I can say this.......I've never seen any disadvantages to using the 8" wheels for bowls up to 16" in diameter. I feel extremely satisfied with the overall results I've been getting.
I also frequently use the Beall 4" buffing wheels.
Although I have a full set of 2", 3", and 4" bowl contoured buffs, I don't use these very much. I can say this about them.....I do use these bowl buffs occasionally, and they are extremely valuable items to have when they are "just right" for any particular need. I would get them, but the 8" and 4" buffing wheels are the most important ones to get......:D
Dan......I realize you are already in the process of using what you have, and that's fine. I am recommending the Beall buffing system only because I feel this outfit has an exceptional product, and there will be others reading this thread whom I wish to present my opinions to.......
One thing that is nice about the Beall buffing wheels.......no tools to change between wheels and takes less than 10 seconds to make the switch! Yay!
Odie - I have the Don Pencil system but I would like to have a stand alone unit that I can quickly change out wheels on for different compounds and wheel sizes - the unit I have will do this fine with the arbors attached to different wheels. When I went to the canton wheels which are the 12" is when I overloaded the 1/3hp machine I have - up until them my wheels up to 4-8" worked fine. I like the large wheels and I agree there is probably no advantage to the larger size but these guitar buffing wheels 12" are much nicer to use than all the other wheels I have tried. The arm on my small machine has a handle for quick disconnecting and attaching on the one side and I like that part of it.
Mike - yes that is what happens - on the lower setting 1725 it will works fine as long as I stay with light pressure. Regarding your Jet Buffer - Do you have the 10" bench top model ? and from little I see of them they can handle the 12 and 14" buffs without any probelm......
I still think im going to look around and get a better machine as I do alot of buffing and polishing............Thanks
You might have to build them a bit of a pedestal for the largest, but it looks like JET has discontinued them. Grizz or one of the other clone peddlers like Woodworkers Supply should do. http://woodworker.com/drum-and-brush-sanding-machine-mssu-120-029.asp?search=buffing&searchmode=2 I like the sanding mop and pneumatic sanding drum for my carvings, but I have to say the mops are a great way to work turnings as well.
Price is over half again the price I paid now.
I went ahead and bought a new buffer - and with the Mezerna and the canton wheels I seem to be doing much better............:D
