Bowl from a board with coring tools?
Marietta, Georgia
I was watching a video on bowl from a board cut on the lathe and tried out the technique today. With a sharp parting tool tool its pretty easy to do. That got me to thinking about using the cutters on coring systems to cut the board with to allow for a more curved profile with less wasted wood. I have a oneway system which would be a bit limiting. Has anyone ever tried this with a McNaughton set?
You may have hit on an innovative approach to getting a nice curve.
The thickness of the cut would be the downside of using a coring blade.
I’ve used the technique to make roofs for full size birdhouses.
Easy way to find out is to draw the cuts. Then see If the rings overlap enough when stacked.
If the don’t you can cut rings from two boards with off sets to use a rings from the two boards to make a stack.[/QUOTE]
I'm almost positive that wouldn't work. The McNaughton would take a minimum of a half-inch kerf and very likely wider as the curve becomes more shallow and wants to drift to the outside of the curve. Also, it isn't designed to cut through the wood and would be difficult to control when the outside of the cutter breaks through. The width of the kerf would probably prevent stacking.
When I've seen the multi flat board approach, they've used a band or jig saw. With either of these tools, I suspect cutting at an angle would lessen the wasted wood. Although I am not sure the extra work would provide a meaningfully better curve than the row of circles cut with a sharp bowl gouge.
I fear the attempt to pre-cut the curve is ripe with opportunities for one level to not line up where it should for the final shape.
Gary Asher (who goes by 'thePapa1947' on Youtube) recently posted a video in which he made a BFB with curved sides by varying the angle the rings were cut at with a thin parting tool. Here's a link to his video:
View: https://youtu.be/XvyJreJA1eg
wasted wood.....bil made that comment many years ago after watching bowl turning...... Ha..... he was a engineer
I may start playing with bfb again. Carol rothman has a scroll saw book on making bowls and has a chart near the end that shows angles. I designed and built a new tool to do this but then life got in the way and I have not used it yet. The metal cutting parting tool is wider at the top and only 1/2" tall so it should work better when cutting the small rings.
I would have to draw it up to know for sure but I am afraid that the kerf taken by even the smallest McNaugton knife would be too wide to work - at least for the whole bowl. As others have noted the secret to getting a nice curve is to vary the angles and minimize the loss from the kerf to ensure that the rings stack with sufficient wall thickness to turn. The bowls I have made this way with curved sides start out with steep sided rings on the bottom (often about 60 degrees) gradually transitioning to as acute as 30 degrees for the last ring. The smallest steepest sided rings need to be cut precisely with the bandsaw to ensure that there is enough wall thickness to allow for final turning after glue up. There is very little room for error on this ring. I made an auxiliary table for my bandsaw that lets me get those last couple of rings where the angle is less than 45 degrees (the limit of the table tilt on my bandsaw). You might be able to take hybrid approach and use the bandsaw for the steeper sided lower rings and use the McNaughton for the upper rings with the more accute angles. There is usually much more wood to turn away there so the loss from the thicker knife might not be an issue. (And it would save you from having to build an auxiliary table).DSC_0620.jpg
Well, it could be done. Not sure if it would be worth the effort. If you have ever seen the video on the New Holland Bowl Mill, they have a large coring tool that they use for the outside roughing cut of a large bowl blank, and use different blades for the inside cores. Their stuff is kind of rough, and not as well finished as most of our bowls are. I would think that a gouge would be more efficient. I don't think even I would approach this type of bowl with a scraper, and all coring systems are scrapers.
I did a little experimenting with a thick chunk of waste wood I had laying around. I mounted it on a chuck and cored it all the way through, then laid the inside on the outside cut. Because of the way the cut is curved you end up with a bit more overlap than a straight cut will give you. In the case the wood was about an inch and a half thick. I got more than an inch wide contact area to glue up and when the bowl was turned to a half inch wall sides angled at about 45 degrees the contact was a half inch wide.
A few pictures, found out the wood was hiding some enormous bug holes so it was never finished out.FE45A60D-6B1E-43C6-B5DB-B19D1EDF3976.jpeg1906FD97-699D-4685-8F23-C6CA3B4CBC16.jpegD2C9A819-E35A-4EFB-88AF-387FB5D97D87.jpegF581E0FF-F16C-429D-AEBE-81AEB9E2553D.jpegF8F63FE1-EA5E-43EF-ADF0-1621D8857B32.jpeg684B9E6C-E561-479B-B5BD-B0D42ACE5C0C.jpegD427838C-B88E-47E1-B61E-9D69B87FADB2.jpeg4C833C9E-9A92-46BE-B86A-1AB615AA2815.jpeg
My dad made this out of a single board , 35+ years ago. It does have a small hole as it was prototype. Foot was added. He turned on a '47 Sears lathe, using mostly scrapers.
Oh, now I understand the original question.... Gary's pictures explained it.... DUH! I have seen parting tools used for this, so a coring tool would work also. I was thinking of the finished glue up and then taking a coring tool to it to rough turn it....
