Boise Crane Model 2700 knowledge?
Hi all,
Has anyone ever heard of or actually used this lathe?
Boise Crane Model 2700. It sure ain't pretty but I have a 'Made in China' starter lathe that I would like to replace with something more substantial and have found that with most power tools, older is better.
From the scant information I have found searching the web it looks like they were in many high school shop rooms years ago.
Thanks very much,
Jim Lee
Hi Jim,
Don't know what is going on with my emails. But here is what I sent.
Hi Jim,
I sent this on my Gmail account, but I thought I should send it again on this one. My gmail does not always work perfectly. :)
Hi Jim,
That lathe look very much like my Boice-Crane. I sold it a couple of years ago to a friend of mine. He moved away but as far as I know it is still working fine.
It was a real fine lathe. I used it for several years before I bought the Oneway. I sold it for 500.00. If it is in sound shape, It would be a real step up from your Harbor Freight lathe. It is much heavier and built like a tank. I used it for spindles for a long time. When I got into turning bowls I added some plywood to the front and back and filled it with 600 lbs of sand in plastic bags :) It stuck to the floor like it was bolted down.
It was a 12 swing like the one you pictured. The gap bed is just for platters and it is just that gap right to the right of the headstock. If you use a chuck it is almost unusable as the chuck and any wood you mount on the chuck make it go past the gap.
Things to check for are the Reeves drive. Made sure it works smoothly. On mine you had to have the lathe running before you could change speeds. Open up the cover when you test it and watch how smoothly the sheaves/pulleys work. Also, I am a bit concerned about where it is stored. I looks like it may be on a dirt floor... maybe not, but I can't tell for sure. If it is check for rust on everything. But to tell you the truth, if it were me I would jump all over it for 300 bucks... that is if everything checks out.
On another note, we lived in Raleigh back in the mid 80s. I worked for 2 years for Cablevision of Raleigh as their underground cable locator.
Good luck and best wishes,
Dave
David Peebles
Lyons, Ohio
Revolutions Woodturning
www.bowlturner.com
Boice-Crane is listed at Old Woodworking Machines ( http://www.owwm.com/ ). Currently listing 38 publication reprints, 120 photos, 7 images, and 34 patents.
According to my very imperfect knowledge, ALL Reeves drives should be operated with the motor running.
