Suggestions please for a finish on a 6 inch bloodwood bowl.
Where do you get the 1# cut of shellac?? Hardware store have it??? GretchThe bloodwood bowl that has been sitting on my shelf for about 8 years was finished with a sanding sealer coat of a 1 pound cut of ultra-blonde shellac, sanded back to 600, and then several spray applications of lacquer as a final finish, buffed with the Beall system including carnauba wax. The finish looks as good today as it did when I finished it. YMMV.
Rob Wallace
Hi again - like Bernie, I have purchased mine from Woodcraft. Also, Woodworkers Supply sells the J.E. Moser's version of Super Blonde that I have used in the past as well. A pound lasts quite a long time if you're using a 1 pound cut and it's used primarily as a sanding sealer. The ability to mix it in small quantities keeps loss due to spoiled shellac to a minimum. It has worked well for me for the past 8 or 9 years or so..... I plan on keeping it as my primary finishing procedure before spraying lacquer.
One last hint - make sure you give the sealer coat enough time to fully dry to get the best sanding characteristics. Sanding too soon simply "gunks-up" [technical term] your sandpaper very quickly.
Good luck!
Rob
How long do you wait before sanding??? With the cellulose sanding sealer it is about 5 minutes. Gretch
