bleaching walnut
Sun City West, Arizona
I've finished a 14" walnut platter and let it sit for a month before finish sanding & sealing. The color has darkened significantly and I'm looking to lighten it up. Has anyone bleached walnut or is there an alternate process without loosing detail? I have sanded it but still dark and don't see the dark grain very much. :confused:
Thank you
Alan bleaching walnut is fun. It will go all the way to a creamy almost white with enough applications. It always looks whiter than it will be after each application. I wipe it down with water after 1 or 2 applications to see what it might look like with finish. It says I. The instructions to use a neutralizer. I never have and it seems to work just fine. I forgot to say this is using a two part wood bleach. Household bleach doesn't work. P
John, Thank you for your insight, I will attempt it.
you'll need lye (pure lye is available as a drain cleaner from hardware stores)
and you'll need a very strong hydrogen peroxide - the article mentioned recommends Bacquacil Step 2 (it's a swimming pool product)
so for about $25 you can make up enough wood bleach to last quite a while.
I used it to lighten some holly I had that was white, but not as white as I wanted and it did very well.
About 3 years ago one of our club members experimented with a product called "Quick White" by Salon care. Comes as a powder (maybe paste) in a bucket and there is also an activator. This is a professional hair care product and I think he purchased from Sally Haircare (professional outlet for beauticians). Seem to me he had turned walnut white with it and was experimenting with time spans to do the job.
Shawn, you say drain cleaner, I had heard that some have metal in them which is not ideal for use in making a wood bleach. What product do you actually use?
Pete
Two-part wood bleach can be purchased online. Klean-Strip brand. It's about $70 for the gallon -- but probably less expensive, and certainly easier and safer -- than making your own. It lasts for a long time. Your club could buy a gallon and share. Or, you may find someone who has the two-part wood bleach you could try. If you live near Indianapolis, I'd give you enough to try.
