- Joined
- Apr 27, 2004
- Messages
- 9,304
- Likes
- 6,058
- Location
- Lakeland, Florida
- Website
- www.hockenberywoodturning.com
To me, the most important element of a video of a demonstration- it must show detail to the person in the last row.
The flat screen TVs produce superb images for a low cost, are semi mobile, and they work very well for those within the viewing distance of the TV. A 60” TV works really well out to anout 30 feet and reasonably well out 40-45 feet. Someone at 60 feet won’t see details or be able to read PowerPoint slides. The suggested viewing distance for TV is 8H that is 8 times the height. A 60” monitor is 31 inches high so 248 inches 21 feet is best.
we all know small things are harder for us to see the further away we get from the object and at some distance we can no longer see the object. This is true for objects on a screen too.
An object that is 1” on a 60” tv will be 2” on a screen projected image 5 ft high.
The average person can see a 1” object about 30 feet away and a 2” object from about 60 feet away.
Here are a couple of screen shots from a demo video that compare how far away you can see detail on a 60” monitor and a projected image.
In the first photo there is nice shot showing the bevel riding cut removing a 1/2”of wood as the bowl is being shaped. On a 60” monitor a viewer further away than 37 feet will not see the tip of the gouge distinctly and not see the bevel contact. On 5 ft and 6 ft projected images the viewers can see up to 72 and 86 feet away respectively.
My first negative experience with TVs was at SWAT in 2014 - a nice lady was sitting in the front row as I was getting ready to repeat a hollowing demo. She said “ I had to come back I was sitting in the back row and I couldn’t see anything.” TVs were too small to see from the back. TVs have a viewing distance. Fill the screen with one letter you can read it across a football field. Put small letters on it and you have a distance limit base on the letter height.
The bottom line is if you have a big room a projector can be seen by all if you project big enough.
You can also cover a big room with multiple TVs -2, 4, 6, or more but a lot of TVs can make a lot of problems with set up storage and cable runs.
We all see at different level and your eyesight may be better or worse. Measure the height of news drag on
And see how far away you can read it.
