anybody know where i can get a replacement belt for a delta midi lathe? I'm in the katrina area & things are still hard to find here.
thanks.
thanks.
Hugh,Hugh said:Anybody have the phone number for Delta to order the belt?
Then the next question is: How much of a project is it to change the belt? I had a Delta Midi lathe deposited in my shop and left there. Then I find that the belt is in need of replacement. I have a bigger lathe and do not use the small one, but would like to repair it for club use.
Thanks.
Hugh
Hugh,
You can go to the Delta web site to download a manual for the LA200 and their phone number is also listed or you can just order the parts over the Internet. The procedure for changing belts is very simple as explained in the instruction manual. It shouldn't take more than a couple minutes.
Bill
Don't follow the manual! They are very casual about the replacement of the belt. They say: Remove handwheel, bearing, and pulley. It took me well over an hour to remove the pulley because the setscrew had twisted and jammed. The belt change requires ONLY that you remove the handwheel and then slide out the bearing. You then have enough room between the shaft and the housing to extract the belt. The whole job should take 5-10 minutes.
Bruce
the part number is 1340949 it is call a v belt. i have the delta midi. i needed to replace the stock belt within the first week. yes, i am a hacking catcher. the replacement belts i got have lasted a little longer but they have stretched and worn pretty quickly for me.
