  • Congratulations to David Wyke, People's Choice in the April 2026 Turning Challenge (click here for details)
  • Congratulations to Roberto Ferrer and Carol Hall for "Waking Dream - Danza Pagana" being selected as Turning of the Week for May 4, 2026 (click here for details)
Bees Wax
I am making several bowls for food use and have decided to finish them with walnut oil followed by a light coat of bees wax. I need some ideas on the best way to apply the bees wax on the bowls. I use the wood-n-things buffing system and am very happy with the results. I have made a new buffing wheel for the bees wax but think it may be to firm. the wax gets sticky to the touch. I do not want to buy a oil/wax mixture because I oil them 5 days and cure them in between with a air circulating oven at about 110 deg. for 8-10 hours. any comments or suggestions.
Don't use bee's wax (or any other wax) on anything intended for anything intended for food service use. As you have noted, bee's wax is soft and sticky -- and will only serve as a bacterial culture medium as it becomes loaded up with food residue. The oil finish alone is sufficient, but I don't think that it is a good idea to use as much oil and heated drying as you do or you may have a similar situation with a soft finish that will take a long time to fully cure.
Bill
Rodney,
I'll echo Bill's comments and go a bit further. Wax of any kind on treenware is a waste of time; it'll be mostly gone after a few washings because it doesn't penetrate wood pores, and any dish detergent (especially with even a smidge of ammonia in it) will strip it right off.
Second, you're treating your oil finish as if it were a solvent finish, and will weaken its effectiveness. "Drying Oil" finishes [refined walnut, linseed, tung, soy, etc.] cure and mature by a process known as polymerization were the oil and resin molecules take in oxygen and chemically form new molecules that link up to form a film. That process may be effected by your heating, but not necessarily in the way you're seeking, as the bonds may be weak because all you're actually doing is driving out the carrier solvents rather than allowing them to be "outgassed" gradually as a function of the polymerization/linking process. Oil finishes actually take several weeks or months to fully polymerize and cure. Rushing them results in weak films. There are any number of good books on wood finishing; Jeff Jewitt, Bob Flexner, or Michael Dresdner have done some of the best. If you read up on how the finishes work, you'll have a better understanding of what to do or not do in a given situation.
For my treenware (food-use) I prefer a mineral oil soak, and then use a cooked combination of mineral oil and parafin wax (85/15 mix) to give a bit of extra sheen to the surface. With each bowl goes a 1/4 cup container of the oil/wax paste so the owner can "refresh" the finish. It's a cheap and effective finish that pops the grain but is completely edible by anyone as it leaches out in use.
m
