bed width top & bottom on 3520B???
Staunton, VA
I ordered my new lathe last week, and I want to be ready for it. I'm digging footings for a concrete foundation, and I want to make a new steady rest for it. I couldn't seem to find the width of the bed ways on either the mustard monster site or the Powermatic manual. It won't be here for at least 2 weeks, and I want to be ready!!:D I'm looking for not only the top width but the bottom of the ways as well--they aren't straight up&down. I'm thinking about having the steady rest frame extend to the bottom of the ways & clamp on the top and the bottom for ridgidity, and to make possible the use of a thinner piece of wood to waste less of the swing capacity of the lathe. It may end up not being necessary, but My current setup with glued & braced ply & 2x4's is just not stiff enough to keep the wheels from vibrating slightly out of position, even when using 2 wing nuts on each slide. I'm going to have braces around the slides so that they are held tightly and cannot move side to side, which should alleviate this, if the sheer mass of the 3520 doesn't stop the vibration by itself.
Thanks in advance turners!
Nate,
The ways on my B are 8" across the top, and 10" across the bottom. The sides are parallel to each other for about 4.5", starting at the bottom. Good luck on your project, and be sure and post photos of the new steady rest!
I've discovered the definition of grief, by relying too heavily on catalog information, good data from others, shop drawings, and even my own measurements. I've had best results with all the hardware actually in hand. Powermatic may have better machining, but accept that the bed may not be perfectly prismatic (uniform cross-section) for the entire length. Include some adjustability, or allowance for refinement, in your design.
That said, I think you'll have better results by using a flat steel bar for the top to minimize encroachment in the swing, and a steel angle bar below the bed. Food for thought: http://n-fl-woodturners.org/images/2008-03/2008-03-03.jpg
[NOTE: This steady rest is NOT for a Powermatic.]
Joe
Thanks for the replies!! I forgot to ask the height of the bed itself, but it seems from the drawings that it is right around 6" from top to bottom. I think I'll just wait and cut out the bed part from a donut ring of sandwiched MDF. The steel bar is perfect, and I never would've thought of the angle iron--thanks. I have a bunch of scrap underneath the shed!
