  • Congratulations to Ted Pelfrey for "Forest Floor" being selected as Turning of the Week for November 4, 2024 (click here for details)
Lafayette, CA
jlwoodshop.com
My first basket illusions following David Nittmann techniques and the YouTube videos of Harvey Meyer. Thank you Harvey for your YouTube videos.
My 3rd and 4th Basket Illusions following Jim Adkins tutorial from 2011. Thank you Jim for a well done tutorial.
  • JL Basket Illusion-1.pdf
  • JL Basket Illusion-2.pdf
Welcome to the AAW forum Jean-Louis. Your work is quite impressive for a new turner. Unfortunately, in the process of merging your two posts together, I somehow deleted the attachments. My mistake for not first making a backup copy. You can edit your post by clicking the word Edit. If you need more help in editing the post please let me know.
Odie
Misssoula, MT
Took awhile to find out how to see them on my computer.......very nice work.
Bill does some very nice basket illusions, as well.......
I am in the process of making another basket illusion. I did the turning and beading early this year. I am just now starting to do the pyrography. I received a new bead burning pen yesterday to replace one that burned out. If you haven't tried the Optima #21 bead burning pen yet, I feel like it is the best by far.
Bill have you tried pens that Harvey Meyer sells. They may come from Optima I don't remember.
Originally the best (probably the only) bead burning pens were made by Detail Master and it was a special design that Jim Adkins had them make. When they went out of business I started a discussion on WoW with Harvey Meyer and several others who did basket illusion pieces. There were some other options that were tried and turned out to be unsatisfactory. Harvey took the initiative and discussed the issue with Pat at PJL (Optima). Harvey sent them a beaded sample that was done with the D-Way beading tool. Pat sawed it in half so that he could get a profile and that is how the Optima bead burning pen design was born. It turned out to be better than the Detail Master design, although not as durable in my experience.
Lafayette, CA
jlwoodshop.com
Bill, I used the 3mm bead tip from Razertip (Canada), but I modified it to fit my beads. I am trying to duplicate the Native American Indian basket that are a bit flat on the top of the bead. A tip cost $9.75 and works fine for me, I do not need to press hard to burn.
The first basket illusion piece that I made after attending a David Nittmann demo had flat top beads and I did all the burning with a skew tipped burning pen. That was a lot of work and discouraged me from doing any more illusion pieces for several years. :D
If you try the D-Way beading tool and the Optima pen I think that you will be very pleased with the realistic end result. I use Copic inks which is what Jim Adkins uses. I don't recall what ink Harvey Meyer uses. I like the Copic inks because they aren't completely opaque.
Lafayette, CA
jlwoodshop.com
The first basket illusion piece that I made after attending a David Nittmann demo had flat top beads and I did all the burning with a skew tipped burning pen. That was a lor of work and discouraged me from doing any more illusion pieces for several years. :D
I use Faber Castell PITT artist pen: Black-M,F,S,XS, Sanguine-B,M,F,S and Sepia-S,B.
Lafayette, CA
jlwoodshop.com
  • Burning Tips for Beads.pdf
I'm familiar with the Razertip design, but wasn't very happy that it was the only thing available for a while after DetailMaster went out of business. I viewed the Razertip as less than satisfactory because most of the heat is dissipated in the wires rather than in the tip which makes it uncomfortable to use for any extended length of time. The cross section of the Optima (and the DetailMaster) tip is such that the greatest electrical resistance is in the arc of the tip which means that is the part that will get the hottest. I was elated when Harvey told me that Optima was able to make a satisfactory pen for him. Initially, it wasn't in their product list, but you had to call them and ask for Pat and say Harvey Meyer sent me ... sort of like going to a speakeasy. :D
Lafayette, CA
jlwoodshop.com
I will call them. I am still please with my modified tip. It can be hot after 3 or 4 hours of use as I do. I decided to reduce my burning time: SPEED vs QUALITY....
Sullivan, Maine
You take your inspiration from whence it comes. The people you've mentioned are, certainly, the giants upon who's shoulders us rookies stand. And I refer to them regularly. One point you and Jim spoke of is design. I think it's great to honor a specific tribe, or even a specific basket maker, by replicating their baskets. However, no where is it written you must do such a thing. In fact, the Native Basket Makers didn't follow specific patterns. They did have a design idea that seemed to show up regularly, but they were pretty creative based on material and colors available. We should do the same.
I'm blessed to live with a wonderful artist. I do all the wood turning, put in the beads and the radial lines. Then I design a Herringbone rim and do all the wood burning. At that point, my eyes are crossed and I hand it off to her. She's usually watching what I'm doing anyway and already has a pattern in mind that may, or may NOT resemble an old basket. From there on, it's her show. We like working that way. I usually have a platter inside drying or in the process of getting wood burned, so she's always got a pattern in mind.
Keep at it and don't be restricted by specific designs. Those old designs ARE worth copying, or at least incorporating into new designs, but don't let them limit you. Here's my latest Herringbone rim example. Maple from our property and Designed by my crazy bride.
