Baseball bats?
Cleveland, Tennessee
I have two grandsons that play baseball in the Dixie Youth League. I have access to their spec's for bats. I'm interested in turning a couple of bats. The boys are 8 and 5-1/2 years old. What are some blank sources? What wood should I use? Finish? Tips for turning (besides sharp tools)? Thanks.
John Woodcraft sells bat blanks. In fact I think I saw some in the Chattanooga store when I was there over Christmas. I could be wrong since I also hit the Nashville store recently.
Thanks. John Lucas, I'll make it a point to stop in WD store in Chattanooga. John Brown, I'll check them out.
gonebatty.com domain name is for sale- nothing there. Searched on "baseball bat blanks" turned up a lot of info- will have to go through them.
Might want to check the rule book to determine if wooden bats are permitted at all. They will have limits on length, weight, girth and such too.
recommend
gonebatty, I have purchased bat blanks from him, 2 years ago, turned 15 bats for my little league team, you want to be sure that if you are going to have them play ball with the bats you make, that they meet the league requirements, size/weight/diameter. they were pretty easy to do, and fun to turn, had a friend with a cnc machine and he put the team/year and kids name on the bat, it was a end of the season thing, there is a lot of specs on goggle. I got my blanks from gone batty, and a few from Woodcraft. good luck! Dennis
I was going to make a wooden bat for a nephew a few years ago and was told he wouldn't be allowed to use it. Aluminum bats only.
Here's a link to a page with links to articles that will answer your questions.
http://www.woodturningonline.com/Turning/Turning_projects.php?catid=9
You also need to accept that there is some probability that if the kid strikes out a couple times with your bat somebody is going to get the blame. And that somebody may be you. I hope the kid hits a homer the first time he uses your bat.
Ed
I checked the Dixie Youth rules- wood bats are allowed and the rules give all the spec's to follow. Will check this year's rules to see if there are any changes. Thanks to all for your replies and links.
John,
If you have not turned bats before a few tips;
Because of the length and diameter of bats, reducing vibration when your turning the middle portion of the bat is very important. A steady rest is neccessary with full sized bats, with the short little league bats, probably still needed?
Turn with the handle portion at the tail stock, this will reduce vibration when your turning in the middle.
Turn from tailstock moving towards the headstock, this too will minimize vibration.
Have a bat on hand to take measurments from (the model you seek to replicate). On the model bat mark lines at several diameter transition places ie the location of the greatest and smallest diameter, each end of the grip portion of the bat etc. Turn the ash blank to a cylinder, then mark lines in the same locations as your measurements from the model bat you are trying to replicate. Use a parting tool to cut where the lines are marking those locations. Part down to the corresponding diameters of the model bat. Then you simply turn from one tranisition to another matching the curve to the diameters already established at each end.
Take your time and sand it well, mass produced ash bats are rarely sanded or finished well, your bat should easily be superior to a mass produced one, and as people pick it up and notice this, you may get other people wanting to pay for a homemade one?
Label the bat so that you get referral buisness from others who see your bats.
have a bat to duplicate
I had a bat in front of me and used multiple calipers to get the thickness from ball to the end, steady rest as discussed in previous post is critical, or you will get wobble, I have a homemade steady rest, that worked well, made of roller blade wheels. Dennis
Most bat blanks are long enough that I usually cut off the extra and turn a baseball. When done well they can look convincing like a old used baseball.
When I turned a bat for my granddaughter the management and I soon realized the way kids grow no bat would be suitable for long. We sort of forgot the regulations and made one. The management wood burned in and personalized the Louisville Slugger logo on the barrel. Erin has it displayed in her room.
Now I've got three other granddaughters to do too.:)
Dave F.
