Banjo swap
Stokes County, NC
www.atlaswoodworks.us
Ok folks, strange question, then again maybe not. I am wondering if the banjo from a PM 4224 will fit the lathe bed of a jet 16/42. the reason i ask is i am thinking about getting a 20" bed extension, having my brother fab a bracket and modify leg to drop it down 4" for outboard turning without the hassle of an independant outboard rest.
I'm not sure about the 16/42 but it will fit the 3520 however it is too tall to be used properly for that lathe. If I read you correctly you want to use it only as a separate banjo for the lowered bed extension. I'm pretty sure it will work. It's flat on the bottom so it will sit on the bed just fine. You might have to change the locking plate and shorten the screw that holds it but that shouldn't be hard.
I thought you wanted to swap a banjo. I've wanted a new banjo along with a 12 string guitar. :)
IF it is not too tall at the top of the banjo (and will accomodate a toolpost and still be adjustable above and below center), it would not be that tough to make a new clamp plate for it. It would only require some basic tooling on a small mill.
Having just measured it myself, keep in mind that the ways are different between the two lathes. If you are going to use the big banjo then you probably want to start with a Powermatic extension, not a jet.
Marc
Marc is right. I would look at the powermatic riser for the banjo. It was designed for a 1" post and works with the standard 3520 tool rest banjo so it would probably work on your Jet as well. Then you would just have to put the extension at the right height so the tool rest riser wold would work.
