Emilliano...I have the same saw, and here is what I use. They are 3/8" wide, and .032 thick, where most blades are .025 thickness, they come with 3 tpi, and a wider tooth set for clearing the kerf. They are specially made for woodturners to cut green wood, and bowl blanks. They work better than Timberwolf blades, and most others. I have used them for about 4 years now on both my bandsaws and highly recommend them. With proper tension, and the guides on your saw properly setup, they cut like a dream!
Trust me on this! Here is the link,
https://www.highlandwoodworking.com/woodturners-bandsawblade.aspx
Your saw will either use a 137" blade or a 133" blade depending on the particular time it was manufactured. Mine uses the 137". They will make the blades to your length, and you can see the price right on the page when you put in your length. Highland has great customer service.
