Has anyone out there installed the Wolverine bases under a Baldor 8" grinder?
The heavy cast guard/dust chute appears to be in the way. My present main grinder is 30+year old American made Delta/Rockwell that has an added bolt on platform that works well. I have always liked the Wolverine adjustable platform for its ease of changing angles so I borrowed a Wolverine base and it looks like the cast guards are in the way even when the grinder is raised to the suggested height.
Since my grinder is a 7" I thought about getting a Baldor 8". Upon inspection of a Baldor, it appears that the Wolverine base interferes with the cast iron guard even more so than with my Delta. (Wolverine base installs 6-1/4 to 6-1/2 below centerline of wheel)
So if a Wolverine jig is to be installed on a grinder with cast iron guards, what is the solution? Remove the guards?
