Bad Move
Been a year since I lost a piece, and this one may not be a total loss, but there's a lesson attached, so thought I'd bring it up.
Waterlogged red oak, not the friendliest of woods, but cut with the heart down to get the greatest number of pieces out of my gift chunks. While downstairs putting the wash in, I noticed this big check across the bottom. Since I'm generally pretty good at noticing preexisting heart checks, even in very wet wood, I'm going to discount that as the cause. What caused it was a combination of making the base pretty broad, which means more wood to pull against, this being a 3.3 in mortise, and my own stupidity in stacking it base up to the open air rather than base down, where the compression from the sides against the wetter wood should keep anything closed. Don't know why I did that, save for convenience, but it cost me. If I hadn't needed the floor space, it would still be sitting on its bottom in the shop.
Last failure I had on a blank was a year ago when I dummied up and left a cherry blank under the heating duct in the downrush of hot air. Needed a fire, so I built one, and never thought about where I had the roughs sitting.
So don't dummy up and be your own worst enemy. I'm going to try and turn for bottom on this check in hopes of saving the bowl in a shallower form.
EDIT: Double brain f*rt. Of course, with heart down it would not be under compression, but tension. Noticed that the eccentricity diminished as I went up toward the rim while cutting. About a quarter inch deep, and opened along the rays, of course. Going to have to be careful on the bottom of this one, because it's already thinner than the sides. Wish me luck.
Hit it with a good shot of super glue right down the crack. It wicks amazingly and will help stop it from progressing.
Dietrich
Did so after turning it down to where I had to half guess at the roots. Also wrote myself a note on the recess to go shallow with the bottom, since it's a bit thinner than I normally start with now. Still enough depth to the bowl for a salad cut, if I thin the walls to about 1/4 to keep the CG low, but have to kick myself for being so casual with what, for me, is a rarely obtained wood.
Where is ya?
When I'm fooling with blanks like that, I keep a bit of an eye on them and, as soon as a crack appears, I CA it. All I'm trying to do is add a bit of structural strength for while it's drying. Mostly, I just leave then really thick then turn off the cracks.
Dietrich
